Logic 2 Error Messages
Click on the error code in the table below to learn more about that specific error message.
Error CodeDescription
StartCommandErrorThis error message appears when the Start command fails.
DeviceSetupFailureThis error message appears when the Start command fails.
ReadTimeoutThis error message appears when the device side buffer has run out of memory caused by delays on the USB line during data capture.
General Error Messages
These error messages do not have an error code associated with them. You can learn more in the links below.
Error Message: Unable to detect WebGL and Other GPU Issues
Warning Message: Logic Pro is running as a USB 2.0 device
Warning Message: Possible USB Host Controller Problem Detected
Sharing your Machine ID
Our support team may require you to send your Machine ID to help us investigate any issues you may be having when using our software. Please refer to the link below to share your Machine ID with us.
Getting your Machine ID
