Which Version of the Software Should I Use?
EditIn almost all cases, you should use the latest release of the Saleae software, Logic 2. It can be found here below:
Logic 1.x (older)
Logic 1.x Beta
The latest version of our older Logic 1.x software can be downloaded here:
Other General Notes
If you are using one of the newer products (Logic 4, Logic 8, Logic Pro 8, Logic Pro 16), you will not be able to use older versions of the software. The only older version you should consider using is if you are on Linux and the latest software is not working (as in the case of CentOs 6.x). In that case, you should try either the compatibility release of the latest version or the compatibility release of the 1.1.34 software, as mentioned in the CentOs section.
The original Logic device is supported on all releases, including the original Windows-only software, versions 1.0.0 through 1.0.34.
The original Logic16 is supported over versions 1.1.14 and newer.
