Legacy — Logic 1.x
This article applies to the discontinued Logic 1.x software. See Logic 2 docs
Starting October of 2022, Saleae has released a new hardware revision of our Logic analyzers which requires the latest version of the Logic 2 software available here. This newer revision of the hardware will no longer work with our legacy Logic 1.x software.
Logic Hardware Revisions
Logic 1.2.40
Windows 64-bit standalone release:
https://downloads.saleae.com/logic/1.2.40/Logic-1.2.40-Windows.zip
Please be aware of the following requirements for the Windows standalone release:
  • The Microsoft Visual Studio runtime needs to be installed before the software will run.
  • If drivers are not already installed from a previous installation of the Logic software, you will need to install the drivers manually. You can find instructions for installing our drivers in the link below.
Driver Install
Mac OS X 10.8+
https://downloads.saleae.com/logic/1.2.40/Logic-1.2.40-MacOS.dmg
Linux 64-Bit
https://downloads.saleae.com/logic/1.2.40/Logic-1.2.40-Linux.AppImage
Extracting the AppImage (Linux)
You can extract the AppImage with ./Logic-1.2.40-Linux.AppImage --appimage-extract, which will dump the contents to a new directory called squashfs. You can then run the Logic binary directly from there.
On Linux, please keep in mind that we no longer store the settings.xml file, calibration downloads, and other temporary files in the same directory structure as the application. Those are now stored in standard directories such as the following:
~/.config/Logic
or
~/.local/share/Logic
Where is the Decoded Protocols Panel?
Unfortunately, the Decoded Protocols Panel, in addition to Protocol Search, is no longer available in 1.2.40 due to technical issues. When attempting to enable it in 1.2.40, you will find our note about it in the screenshot below. Please upgrade to our newer Logic 2 software if you need this functionality.
Decoded Protocol Search is no longer availble in 1.2.40
Older Versions of Logic 1.x
Temporary Releases
We released a temporary fix for processor incompatibilies mentioned in the support article below. The fixes have been implemented in v1.2.40, however, you may still need to use the temporary release versions mentioned below (v1.2.35 for Windows and v1.2.33 for MacOS) if you require using the Decoded Protocols Panel, which is not included in v1.2.40 due to technical issues.
Error Function: Device2::SetupDevice
1.2.29 Beta Download
Before the release of 1.2.40, this was the last version of Logic 1.x that we recommened for use.
Windows
Logic Setup 1.2.29.exe
Mac OS X 10.8+
Logic-1.2.29-Darwin.dmg
Linux 64-Bit
https://downloads.saleae.com/logic/1.2.29/Logic+1.2.29+(64-bit).zip
Windows Standalone releases:
Note: These releases include the newly required Microsoft Visual Studio 2015 runtime. The runtime needs to be installed before the software will be able to run.
Windows 32-Bit Standalone
https://downloads.saleae.com/logic/1.2.29/Logic+1.2.29+Win+32+Standalone.zip
Windows 64-Bit Standalone
https://downloads.saleae.com/logic/1.2.29/Logic+1.2.29+Win+64+Standalone.zip
Workaround for the “Unsupported Version” Error
When launching 1.2.29, you may see an “Unsupported Version” notice like shown below.
Unsupported Version warning message in Logic 1.x
If you see this notice, please start the software using the instructions in the support article below.
Warning Message: Unsupported Version
1.2.28 Beta Download
Windows (32 bit and 64 bit):
https://downloads.saleae.com/logic/1.2.28/Logic+Setup+1.2.28.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.28/Logic-1.2.28-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.28/Logic+1.2.28+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.28/Logic+1.2.28+(64-bit)+compatibility_release.zip
Widows Standalone Releases:
Windows 32 bit (no installer):
https://downloads.saleae.com/logic/1.2.28/Logic+1.2.28+Win+32+Standalone.zip
Windows 64 bit (no installer):
https://downloads.saleae.com/logic/1.2.28/Logic+1.2.28+Win+64+Standalone.zip
1.2.27 Beta Download
https://downloads.saleae.com/logic/1.2.27/Logic+Setup+1.2.27.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.27/Logic-1.2.27-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.27/Logic+1.2.27+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.27/Logic+1.2.27+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.27/Logic+1.2.27+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.27/Logic+1.2.27+Win+64+Standalone.zip
1.2.26 Beta Download
https://downloads.saleae.com/logic/1.2.26/Logic+Setup+1.2.26.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.26/Logic-1.2.26-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.26/Logic+1.2.26+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.26/Logic+1.2.26+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.26/Logic+1.2.26+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.26/Logic+1.2.26+Win+64+Standalone.zip
1.2.25 Beta Download
https://downloads.saleae.com/logic/1.2.25/Logic+Setup+1.2.25.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.25/Logic-1.2.25-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.25/Logic+1.2.25+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.25/Logic+1.2.25+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.25/Logic+1.2.25+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.25/Logic+1.2.25+Win+64+Standalone.zip
1.2.24 Beta Download
https://downloads.saleae.com/logic/1.2.24/Logic+Setup+1.2.24.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.24/Logic-1.2.24-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.24/Logic+1.2.24+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.24/Logic+1.2.24+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.24/Logic+1.2.24+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.24/Logic+1.2.24+Win+64+Standalone.zip
1.2.23 Beta Download
https://downloads.saleae.com/logic/1.2.23/Logic+Setup+1.2.23.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.23/Logic-1.2.23-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.23/Logic+1.2.23+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.23/Logic+1.2.23+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.23/Logic+1.2.23+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.23/Logic+1.2.23+Win+64+Standalone.zip
1.2.22 Beta Download
https://downloads.saleae.com/logic/1.2.22/Logic+Setup+1.2.22.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.22/Logic-1.2.22-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.22/Logic+1.2.22+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.22/Logic+1.2.22+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.22/Logic+1.2.22+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.22/Logic+1.2.22+Win+64+Standalone.zip
1.2.20 Beta Download
https://downloads.saleae.com/logic/1.2.20/Logic+Setup+1.2.20.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.20/Logic-1.2.20-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.20/Logic+1.2.20+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.20/Logic+1.2.20+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.20/Logic+1.2.20+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.20/Logic+1.2.20+Win+64+Standalone.zip
1.2.19 Beta Download
https://downloads.saleae.com/logic/1.2.19/Logic+Setup+1.2.19.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.19/Logic-1.2.19-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.19/Logic+1.2.19+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.19/Logic+1.2.19+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.19/Logic+1.2.19+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.19/Logic+1.2.19+Win+64+Standalone.zip
1.2.18 Download
https://downloads.saleae.com/logic/1.2.18/Logic+Setup+1.2.18.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.18/Logic-1.2.18-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.18/Logic+1.2.18+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.18/Logic+1.2.18+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.18/Logic+1.2.18+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.18/Logic+1.2.18+Win+64+Standalone.zip
1.2.17 Download
https://downloads.saleae.com/logic/1.2.17/Logic+Setup+1.2.17.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.17/Logic-1.2.17-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.17/Logic+1.2.17+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.17/Logic+1.2.17+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.17/Logic+1.2.17+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.17/Logic+1.2.17+Win+64+Standalone.zip
1.2.16 Download
https://downloads.saleae.com/logic/1.2.16/Logic+Setup+1.2.16.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.16/Logic-1.2.16-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.16/Logic+1.2.16+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.16/Logic+1.2.16+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.16/Logic+1.2.16+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.16/Logic+1.2.16+Win+64+Standalone.zip
1.2.15 Download
https://downloads.saleae.com/logic/1.2.15/Logic+Setup+1.2.15.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.15/Logic-1.2.15-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.15/Logic+1.2.15+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.15/Logic+1.2.15+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.15/Logic+1.2.15+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.15/Logic+1.2.15+Win+64+Standalone.zip
1.2.14 Download
https://downloads.saleae.com/logic/1.2.14/Logic+Setup+1.2.14.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.14/Logic-1.2.14-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.14/Logic+1.2.14+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.14/Logic+1.2.14+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.14/Logic+1.2.14+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.14/Logic+1.2.14+Win+64+Standalone.zip
1.2.13 Download
https://downloads.saleae.com/logic/1.2.13/Logic+Setup+1.2.13.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.13/Logic-1.2.13-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.13/Logic+1.2.13+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.13/Logic+1.2.13+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.13/Logic+1.2.13+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.13/Logic+1.2.13+Win+64+Standalone.zip
1.2.12 Download
https://downloads.saleae.com/logic/1.2.12/Logic+Setup+1.2.12.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.12/Logic-1.2.12-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.12/Logic+1.2.12+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.12/Logic+1.2.12+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.12/Logic+1.2.12+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.12/Logic+1.2.12+Win+64+Standalone.zip
1.2.11 Download
https://downloads.saleae.com/logic/1.2.11/Logic+Setup+1.2.11.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.11/Logic-1.2.11-Darwin.dmg
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.11/Logic+1.2.11+(64-bit).zip
Linux Compatibility release, for users with older libraries: Linux 64 bit - not yet tested after update to QT 5.7. https://downloads.saleae.com/logic/1.2.11/Logic+1.2.11+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.11/Logic+1.2.11+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.11/Logic+1.2.11+Win+64+Standalone.zip
1.2.10 Download
https://downloads.saleae.com/logic/1.2.10/Logic+Setup+1.2.10.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.10/Logic-1.2.10-Darwin.dmg
Linux 32 bit:
https://downloads.saleae.com/logic/1.2.10/Logic+1.2.10+(32-bit).zip
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.10/Logic+1.2.10+(64-bit).zip
Linux 32 bit:
https://downloads.saleae.com/logic/1.2.10/Logic+1.2.10+(32-bit)+compatibility_release.zip
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.10/Logic+1.2.10+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.10/Logic+1.2.10+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.10/Logic+1.2.10+Win+64+Standalone.zip
1.2.9 Download
https://downloads.saleae.com/logic/1.2.9/Logic+Setup+1.2.9.exe
OSX 10.7+:
https://downloads.saleae.com/logic/1.2.9/Logic-1.2.9-Darwin.dmg
Linux 32 bit:
https://downloads.saleae.com/logic/1.2.9/Logic+1.2.9+(32-bit).zip
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.9/Logic+1.2.9+(64-bit).zip
Linux 32 bit:
https://downloads.saleae.com/logic/1.2.9/Logic+1.2.9+(32-bit)+compatibility_release.zip
Linux 64 bit:
https://downloads.saleae.com/logic/1.2.9/Logic+1.2.9+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/logic/1.2.9/Logic+1.2.9+Win+32+Standalone.zip
https://downloads.saleae.com/logic/1.2.9/Logic+1.2.9+Win+64+Standalone.zip
1.2.8 Download
https://downloads.saleae.com/betas/1.2.8/Logic+Setup+1.2.8.exe
OSX 10.7+:
https://downloads.saleae.com/betas/1.2.8/Logic-1.2.8-Darwin.dmg
Linux 32 bit:
https://downloads.saleae.com/betas/1.2.8/Logic+1.2.8+(32-bit).zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.2.8/Logic+1.2.8+(64-bit).zip
Linux 32 bit:
https://downloads.saleae.com/betas/1.2.8/Logic+1.2.8+(32-bit)+compatibility_release.zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.2.8/Logic+1.2.8+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/betas/1.2.8/Logic+1.2.8+Beta+Win+32+Standalone.zip
https://downloads.saleae.com/betas/1.2.8/Logic+1.2.8+Beta+Win+64+Standalone.zip
1.2.7 Download
https://downloads.saleae.com/betas/1.2.7/Logic+Setup+1.2.7.exe
OSX 10.7+:
https://downloads.saleae.com/betas/1.2.7/Logic-1.2.7-Darwin.dmg
Linux 32 bit:
https://downloads.saleae.com/betas/1.2.7/Logic+1.2.7+(32-bit).zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.2.7/Logic+1.2.7+(64-bit).zip
Linux 32 bit:
https://downloads.saleae.com/betas/1.2.7/Logic+1.2.7+(32-bit)+compatibility_release.zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.2.7/Logic+1.2.7+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/betas/1.2.7/Logic+1.2.7+Beta+Win+32+Standalone.zip
https://downloads.saleae.com/betas/1.2.7/Logic+1.2.7+Beta+Win+64+Standalone.zip
1.2.5 Download
https://downloads.saleae.com/betas/1.2.5/Logic+Setup+1.2.5.exe
OSX 10.7+:
https://downloads.saleae.com/betas/1.2.5/Logic-1.2.5-Darwin.dmg
Linux 32 bit:
https://downloads.saleae.com/betas/1.2.5/Logic+1.2.5+(32-bit).zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.2.5/Logic+1.2.5+(64-bit).zip
Linux 32 bit:
https://downloads.saleae.com/betas/1.2.5/Logic+1.2.5+(32-bit)+compatibility_release.zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.2.5/Logic+1.2.5+(64-bit)+compatibility_release.zip
https://downloads.saleae.com/betas/1.2.5/Logic+1.2.5+standalone+32+bit.zip
https://downloads.saleae.com/betas/1.2.5/Logic+1.2.5+standalone+64+bit.zip
1.2.4 Download
https://downloads.saleae.com/betas/1.2.4/Logic+Setup+1.2.4.exe
OSX 10.7+:
https://downloads.saleae.com/betas/1.2.4/Logic-1.2.4-Darwin.dmg
Linux 32 bit:
https://downloads.saleae.com/betas/1.2.4/Logic+1.2.4+(32-bit).zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.2.4/Logic+1.2.4+(64-bit).zip
Linux 32 bit:
https://downloads.saleae.com/betas/1.2.4/Logic+1.2.4+(32-bit)+compatibility_release.zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.2.4/Logic+1.2.4+(64-bit)+compatibility_release.zip
1.2.3 Download
https://downloads.saleae.com/betas/1.2.3/Logic+Setup+1.2.3.exe
OSX 10.7+:
https://downloads.saleae.com/betas/1.2.3/Logic-1.2.3-Darwin.dmg
Linux 32 bit:
https://downloads.saleae.com/betas/1.2.3/Logic+1.2.3+(32-bit).zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.2.3/Logic+1.2.3+(64-bit).zip
Linux Compatibility release”
Linux 32 bit:
https://downloads.saleae.com/betas/1.2.3/Logic+1.2.3+(32-bit)+compatibility_release.zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.2.3/Logic+1.2.3+(64-bit)+compatibility_release.zip
Standalone Windows (no installer):
Windows 32 bit:
https://downloads.saleae.com/betas/1.2.3/Logic+1.2.3+Windows+32+bit+Standalone.zip
Windows 64 bit:
https://downloads.saleae.com/betas/1.2.3/Logic+1.2.3+Windows+64+bit+Standalone.zip
1.2.2 Download
https://downloads.saleae.com/betas/1.2.2/Logic+Setup+1.2.2.exe
osx 10.7+
https://downloads.saleae.com/betas/1.2.2/Logic-1.2.2-Darwin.dmg
Linux 32 bit:
https://downloads.saleae.com/betas/1.2.2/Logic+1.2.2+(32-bit).zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.2.2/Logic+1.2.2+(64-bit).zip
Linux 32 bit compatibility release:
https://downloads.saleae.com/betas/1.2.2/Logic+1.2.2+(32-bit)+compatibility_release.zip
Linux 64 bit compatibility release:
https://downloads.saleae.com/betas/1.2.2/Logic+1.2.2+(64-bit)+compatibility_release.zip
1.2.1 Download (Linux and OSX only)
OSX 10.7+
https://downloads.saleae.com/betas/1.2.1/Logic-1.2.1-Darwin.dmg
Linux 32 bit:
https://downloads.saleae.com/betas/1.2.1/Logic+1.2.1+(32-bit).zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.2.1/Logic+1.2.1+(64-bit).zip
1.1.34 Download
Windows: (32 bit and 64 bit)
https://downloads.saleae.com/betas/1.1.34/Logic+Setup+1.1.34.exe
OSX:
https://downloads.saleae.com/betas/1.1.34/Logic-1.1.34-Darwin.dmg
Linux 32 bit:
https://downloads.saleae.com/betas/1.1.34/Logic+1.1.34+(32-bit).zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.1.34/Logic+1.1.34+(64-bit).zip
https://downloads.saleae.com/betas/1.1.34/Logic+1.1.34+(32-bit)+compatibility_release.zip
https://downloads.saleae.com/betas/1.1.34/Logic+1.1.34+(64-bit)+compatibility_release.zip
Windows 32 bit standalone:
https://downloads.saleae.com/standalone/Saleae+LLC+v1.1.34+x32+standalone.zip
Windows 64 bit standalone:
https://downloads.saleae.com/standalone/Saleae+LLC+v1.1.34+x64+standalone.zip
1.1.20 Download
Windows 32:
https://downloads.saleae.com/betas/1.1.20/Logic+Setup+1.1.20+(32-bit).exe
Windows 64:
https://downloads.saleae.com/betas/1.1.20/Logic+Setup+1.1.20+(64-bit).exe
Linux 32:
https://downloads.saleae.com/betas/1.1.20/Logic+1.1.20+(32-bit).zip
Linux 64:
https://downloads.saleae.com/betas/1.1.20/Logic+1.1.20+(64-bit).zip
OSX 10.6+
https://downloads.saleae.com/betas/1.1.20/Logic-1.1.20-Darwin.dmg
1.1.19 Download
Linux 32 bit:
https://downloads.saleae.com/betas/1.1.19/Logic+1.1.19+(32-bit).zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.1.19/Logic+1.1.19+(64-bit).zip
Windows 32 bit:
https://downloads.saleae.com/betas/1.1.19/Logic+Setup+1.1.19+(32-bit).exe
Windows 64 bit:
https://downloads.saleae.com/betas/1.1.19/Logic+Setup+1.1.19+(64-bit).exe
OSX 10.6+
https://downloads.saleae.com/betas/1.1.19/Logic-1.1.19-Darwin.dmg
1.1.18 Linux interim Download
(released after 1.1.18 with Linux specific USB fixes)
Linux 32 bit
https://downloads.saleae.com/Logic+Socket+Beta+Update/Logic+1.1.18+-+beta+update+(32-bit).zip
Linux 64 bit
https://downloads.saleae.com/Logic+Socket+Beta+Update/Logic+1.1.18+-+beta+update+(64-bit).zip
1.1.18 Download
Windows:
Logic 1.1.18 Beta - Windows 32 bit
Logic 1.1.18 Beta - Windows 64 bit
OS X:
Logic 1.1.18 Beta - OSX 10.6+
Linux 32 bit:
https://downloads.saleae.com/betas/1.1.18/Logic+1.1.18+(32-bit).zip
Linux 64 bit:
https://downloads.saleae.com/betas/1.1.18/Logic+1.1.18+(64-bit).zip
Windows Standalone:
32 bit:
https://downloads.saleae.com/betas/1.1.18/Logic1.1.18BetaWin32Standalone.zip
64 bit:
https://downloads.saleae.com/betas/1.1.18/Logic1.1.18betaWin64Standalone.zip
Legacy Software for OSX 10.4 and 10.5
Starting with beta release 1.1.18, we stopped supporting OSX versions earlier than 10.6. More recently. we only support 10.7 and newer. That is because with newer versions of OSX, it has become impossible to compile our required libraries with support for these older platforms.
1.1.15 was the last release to support OSX 10.4 and 10.5. You can download them here:
OSX 10.4+
https://old.saleae.com/downloads/logic/Logic%201.1.15%20(10.4+).zip
OSX 10.5+
https://old.saleae.com/downloads/logic/Logic%201.1.15%20(10.5+).pkg
These releases only support the original Logic and Logic16 and none of the Gen2 products (Logic 4, Logic 8, Logic Pro 8 and Logic Pro 16).
1.1.15 Download
https://downloads.saleae.com/standalone/Logic+1.1.15+standalone.zip
Note, 1.1.15 was the last 32 bit only release. There is only 1 version for both 32 bit and 64 bit versions of windows. The reason there are two installers for 1.1.15 is to simply support installing the different drivers for 32 bit and 64 bit windows, both of which are included in this one standalone release.
About Legacy .logicsession Files
Original versions of the software were written in .NET and were Windows only. Back then, we used Windows serialization to save .logicdata files. In later versions of Logic 1.x software, we have moved to cross-platform software using Boost for serialization. These two serializations are not compatible and require different versions of the software to open. Unfortunately, there is no way to convert from one version to the other, making the older versions impossible to open in new versions of the software.
To open any files saved with version v1.0.34 or older, you can still open the files with an older version of the software. Below are links to an older version of the software that should open them just fine.
Please note that this software was last released in late 2010 and should not be confused with the new software versions that started with 1.1.0. All software releases in the range 1.0.x were Windows only, and all releases 1.1.x were cross-platform.
v1.0.34:
32 bit:
https://downloads.saleae.com/Logic+Setup+1.0.34+(32-bit).exe
64 bit:
https://downloads.saleae.com/Logic+Setup+1.0.34+(64-bit).exe
