LIN - Frame Format
Output Frame Format
Frame Type: "no_frame"
PropertyTypeDescription
  • undefined
  • Inter-byte space
Frame Type: "header_break"
  • undefined
  • Header break
Frame Type: "header_sync"
  • undefined
  • Header sync
Frame Type: "header_pid"
protected_idint6 bit protected Id
  • Protected identifier
Frame Type: "data"
dataintData byte
indexintIndex, 0-8, of the data byte inside of the transaction
Frame Type: "checksum"
checksumintLIN checksum
  • Checksum byte
Frame Type: "data_or_checksum"
dataintData byte
  • Unable to determine if this byte is a data byte or a checksum. It is technically valid as both. This occurs if a a data byte, at index N, is equal to what the CRC should be if the transaction is N-1 bytes.
