I2C - Frame Format
EditI2C Communication Overview
I2C communication involves two roles: a master and a slave. The master initiates and controls the communication, while the slave responds to the master’s requests. Data transmission on the I2C bus is organized into transactions, each starting with a START condition and ending with a STOP condition. Each transaction begins with a 7-bit address and comprises one or more data bytes, with each byte followed by an acknowledgment from the receiver.
I2C Frame Evaluation
I2C communication is captured as frames by a built-in low-level I2C analyzer. Each frame represents one byte of information. Frame types are defined below including: start, address, data, and stop.
Data Frame Evaluation
The HLA executes once for each incoming frame. Each frame contains only one byte. Each transaction begins with a start frame, an address frame, and then any number of data frames, ending with a stop frame. A state machine is often needed to decode multi-byte (multi-frame) sequences such as a command followed by a parameter.
Output Frame Format
Frame Type: "address"
- I2C address byte
| Property | Type | Description |
address | byte | The 7 bit I2C address |
read | bool | True for read operations, false for write operations |
ack | bool | True when the address was ACKed, false when NAKed |
error | str | (optional) Present if an there was a problem reading the I2C data |
Example
Store the address as an integer and display it on the terminal as a hex value
if frame.type == 'address': address = frame.data['address'][0] print(f"Address: {hex(address)}")Result
Data: 0x3CFrame Type: "data"
- I2C data byte
data | byte | single 8 bit data word |
ack | bool | True when the data byte was ACKed, false when NAKed |
Example
Store the data value as an integer and display it on the terminal as a hex value
if frame.type == 'data': data = frame.data['data'][0] print(f"Data: {hex(data)}")Result:
Data: 0x00Frame Type: "start"
- undefined
- I2C start condition
Frame Type: "stop"
- undefined
- I2C stop condition
