1-Wire - Frame Format
Output Frame Format
Frame Type: "reset"
PropertyTypeDescription
  • Reset pulse
Frame Type: "presence"
  • Presence Pulse
Frame Type: "rom_command"
descriptionstrread, skip, search, or match
rom_commandbytesThe command byte
  • ROM command. This is the first command issued by the master after a presence pulse
Frame Type: "crc"
crcbytesThe CRC byte
  • 8 bit CRC, last part of the 64 bit identifier
Frame Type: "family_code"
familybytesThe family code, which is the first part of the 64 bit identifier
  • The family code of the device ID
Frame Type: "id"
idint48 bit integer, taken from the center of the 64 bit identifier
  • The 48 bit device identifier
Frame Type: "data"
databytesA single data byte
  • Data byte after the ROM command and identifier
Frame Type: "invalid_rom_command"
rom_commandbytesThe ROM command byte
  • Unknown ROM command
Frame Type: "alarm"
  • Alarm search command
