Connecting the Logic Analyzer
  1. Open the Logic 2 software
  2. Connect one end of the included USB cable to the Logic analyzer
  3. Connect the other end of the USB cable to the PC’s USB port. Ensure that the proper USB port is used for the specific device. Due to the amount of bandwidth required, it is recommended to directly connect to the PC’s USB port rather than through a docking station or a USB hub.
    • Logic Pro 8 and Logic Pro 16 require a USB 3.0 port.
    • Logic 8 requires at least a USB 2.0 port.
    • Our discontinued products (Original Logic, Logic16, and Logic 4) require at least a USB 2.0 port.
  4. Once connected to the PC, the software will begin configuring the device and the LED on Logic should turn on.
Connecting Logic to your PC
If connecting Logic Pro 8 or Logic Pro 16 to a USB 2.0 port, please read the article below. You may receive a warning notification from within the software which indicates that the available channels and sampling rate options may be limited.
Warning Message: Logic Pro is running as a USB 2.0 device
