Digital Measurement Extensions
Usage: High Level Analyzers Can be installed from within Logic 2 by navigating to ‘Extensions’ in the right hand menu and selecting ‘install’ on the extension of your choice. The extensions are listed alphabetically.
Clock Stats ★ 1
Version: 0.0.2
Author: Saleae
Description: Builtin clock stats - Average frequency, edge count, etc
Extensions:
- clockStats: Type: DigitalMeasurement
- Metrics:
- edgesFalling: No. Falling Edges (Nfalling)
- edgesRising: No. Rising Edges (Nrising)
- frequencyMin: Minimum Frequency (fmin)
- frequencyMax: Maximum Frequency (fmax)
- frequencyAvg: Average Frequency (fmean)
- periodStdDev: Period STD (Tstd)
- Metrics:
Average Period ★ 0
Version: 0.0.1
Author: Tim Reyes
Description: Digital measurement for avg period
Extensions:
- AvgPeriod: Type: DigitalMeasurement
- Metrics:
- averagePeriod: Average Period (Tavg)
- Metrics:
Pulse Count ★ 1
Version: 0.0.1
Author: Tim Reyes
Description: Count pos and neg pulses
Extensions:
- Pulses: Type: DigitalMeasurement
- Metrics:
- positivePulses: Positive Pulses (Np(+))
- negativePulses: Negative Pulses (Np(-))
- Metrics:
Total Periods ★ 0
Version: 0.0.1
Author: Tim Reyes
Description: Digital measurement for total periods
Extensions:
- min pos pulse: Type: DigitalMeasurement
- Metrics:
- totalPeriods: Total Periods (Ptotal)
- Metrics:
Duty Cycle ★ 1
Version: 0.0.1
Author: Tim Reyes
Description: Digital Measurement for duty cycle
Extensions:
- DutyCycle: Type: DigitalMeasurement
- Metrics:
- dutyCycle: Duty Cycle (Dcycle)
- Metrics:
Idle Period Count ★ 0
Version: 0.0.1
Author: Mark Blackburn (Blackbeard Software)
Description: Count idle periods in a signal
Extensions:
- Idle Search: Type: DigitalMeasurement
- Metrics:
- idlePeriods: Idle Periods (Ni)
- Metrics:
Baud rate estimate ★ 4
Version: 1.0.1
Author: Jonathan Reichelt Gjetsen
Description: Estimates the baud rate of a digital signal.
Extensions:
- BaudRateEstimate: Type: DigitalMeasurement
- Metrics:
- baud_rate: Baud rate (fbaud)
- Metrics:
Pulse Stats ★ 3
Version: 1.1.2
Author: Peter Jaquiery
Description: Calculate min, mean and max pulse width stats
Extensions:
- PulseStats: Type: DigitalMeasurement
- Metrics:
- pHMin: High Min (Hmin)
- pHMean: High Mean (Hmean)
- pHSDev: High Std Dev (HSDev)
- pHMax: High Max (Hmax)
- pLMin: Low Min (Lmin)
- pLMean: Low Mean (Lmean)
- pLSDev: Low Std Dev (LSDev)
- pLMax: Low Max (Lmax)
- Metrics:
Fan RPM’s ★ 0
Version: 0.0.1
Author: Cory Klopotic
Description: Measures the RPM’s from a fan using the fan’s TACH signal. TACH signal goes low 2 times per revolution.
Extensions:
- Fan RPM’s: Type: DigitalMeasurement
- Metrics:
- RPM: RPM (RPM)
- Metrics:
Burst Stats ★ 0
Version: 1.0.3
Description: Calculate min, mean and max cycle period stats
Extensions:
- BurstStats: Type: DigitalMeasurement
- Metrics:
- pPMin: Min Period (Pmin)
- pPMean: Mean Period (Pmean)
- pPSDev: Period Std Dev (PSDev)
- pPMax: Max Period (Pmax)
- pBursts: Bursts count (Count)
- Metrics:
task_detector ★ 0
Version: 0.0.1
Author: Evan Noble
Description:
Extensions:
- task_detector: Type: DigitalMeasurement
- Metrics:
- signal_path_bypass: signal_path_bypass (bypass)
- signal_path: signal_path (sp)
- freq_shift: freq_shift (fs)
- aux_out: aux_out (aux)
- compressor: compressor (comp)
- tnr: tnr (tnr)
- sig_gen: sig_gen (sgen)
- mpo: mpo (mpo)
- virtual_fb: virtual_fb (vfb)
- mlnr: mlnr (mlnr)
- fbm_update: fbm_update (fbm_u)
- fbm: fbm (fbm)
- volume: volume (vol)
- Metrics:
CPU load analyzer ★ 0
Version: 0.0.1
Author: Mateusz Syc
Description:
Extensions:
- CPU load monitor: Type: DigitalMeasurement
- Metrics:
- cpu_load_avg: Average CPU load (CPU loadavg)
- cpu_load_max: Max CPU load (CPU loadmax)
- ts_max: Max timestamp (tcpuload max)
- cpu_load_min: Min CPU load (CPU loadmin)
- ts_min: Min timestamp (tcpuload min)
- Metrics:
lowTime ★ 0
Version: 0.0.1
Author: shy coder
Description:
Extensions:
- lowTime: Type: DigitalMeasurement
- Metrics:
- metricKey: <metric_name> (<short_notation>)
- Metrics:
Pulse Interval Stats ★ 0
Version: 0.0.1
Author: Coriander V. Pines
Description: Calculate min, mean, and max interval lengths for pulses.
Extensions:
- Pulse Stats: Type: DigitalMeasurement
- Metrics:
- polarity: Interval Polarity (Ipol)
- count: Interval Count (Icount)
- min: Minimum Interval Length (Imin)
- mean: Mean Interval Length (Imean)
- max: Maximum Interval Length (Imax)
- stddev: Interval Length Standard Deviation (Istddev)
- Metrics:
Period Stats ★ 0
Version: 1.0.0
Description: Calculate min, mean and max period stats
Extensions:
- PeriodStats: Type: DigitalMeasurement
- Metrics:
- pMin: Min (Min)
- pMean: Mean (Mean)
- pFreq: Freq (Freq)
- pSDev: Std Dev (SDev)
- pMax: Max (Max)
- pCount: Count (Count)
- Metrics:
PacketMarker ★ 0
Version: 3.3.5
Author: Nikolay
Description: PacketMarkerCXPI
Extensions:
- PacketMarker: Type: DigitalMeasurement
- Metrics:
- metricKey: Throughput (TP)
- anotherMetricKey: Latency (LT)
- Metrics:
freeRTS ★ 0
Version: 0.0.2
Author: jiemba5
Description: Includes measures for finding utilization data for a sequential Real-Time Systems Task scheduler.
Extensions:
- freeRTS: Type: DigitalMeasurement
- Metrics:
- c_average: Average c (Caverage)
- c_worst: Worst c (Cworst)
- c_best: Best c (Cbest)
- c_std: Std c (Cstd)
- t_complete: Tasks completed (Ncompleted)
- p_average: Average task period (Tmean)
- Metrics:
ws2812 ★ 0
Version: 0.0.1
Author: shy coder
Description:
Extensions:
- ws2812: Type: DigitalMeasurement
- Metrics:
- Metrics:
Hold-time Measurement - High ★ 1
Version: 0.0.2
Author: ZOMLI
Description: Measure the high hold time (between the first low level to the last low level).It will show the sum/mean/max/min of high_hold time in measurement interval
Extensions:
- high_hold measure: Type: DigitalMeasurement
- Metrics:
- highholdsum: hight hold Time sum (THsum)
- highholdmean: hight hold Time mean (THmean)
- highholdmax: hight hold Time max (THmax)
- highholdmin: hight hold Time min (THmin)
- Metrics:
Hold-time Measurement - Low ★ 0
Version: 0.0.2
Author: ZOMLI
Description: Measure the low hold time (between the first low level to the last low level).It will show the sum/mean/max/min of low_hold time in measurement interval
Extensions:
- Metrics:
- lowholdsum: low hold Time sum (TLsum)
- lowholdmean: low hold Time mean (TLmean)
- lowholdmax: low hold Time max (TLmax)
- lowholdmin: low hold Time min (TLmin)
- Metrics:
An Extended Pulse Measurements Plugin ★ 0
Version: 1.0.1
Author: Mark Omo
Description: Measures positive and negative pulse widths, duty cycle, and frequency (mean, min, max).
Extensions:
- ExtendedDigital: Type: DigitalMeasurement
- Metrics:
- posPulseWidthMean: Positive Pulse Width Mean (TposMean)
- posPulseWidthMin: Positive Pulse Width Min (TposMin)
- posPulseWidthMax: Positive Pulse Width Max (TposMax)
- negPulseWidthMean: Negative Pulse Width Mean (TnegMean)
- negPulseWidthMin: Negative Pulse Width Min (TnegMin)
- negPulseWidthMax: Negative Pulse Width Max (TnegMax)
- dutyMean: Duty Cycle Mean (Dutymean)
- dutyMin: Duty Cycle Min (Dutymin)
- dutyMax: Duty Cycle Max (Dutymax)
- freqMean: Frequency Mean (fmean)
- freqMin: Frequency Min (fmin)
- freqMax: Frequency Max (fmax)
- Metrics:
