Analog Measurement Extensions
EditUsage: High Level Analyzers Can be installed from within Logic 2 by navigating to ‘Extensions’ in the right hand menu and selecting ‘install’ on the extension of your choice. The extensions are listed alphabetically.
Voltage RMS ★ 0
Version: 0.0.2
Author: Saleae
Description: Measure RMS voltage
Extensions:
- voltageData: Type: AnalogMeasurement
- Metrics:
- voltageRms: Voltage RMS (VRMS)
- Metrics:
Voltage Min and Max ★ 0
Version: 0.0.1
Author: Tim Reyes
Description: Analog measurement for min/max volts
Extensions:
- MinAndMax: Type: AnalogMeasurement
- Metrics:
- minimum: Minimum (Vmin)
- maximum: Maximum (Vmax</sub)
- Metrics:
Peak-to-Peak Voltage ★ 0
Version: 0.0.1
Author: Tim Reyes
Description: Analog measurement for Vpeak-to-peak
Extensions:
- PeakToPeak: Type: AnalogMeasurement
- Metrics:
- peakToPeak: Peak-To-Peak Voltage (Vpp)
- Metrics:
Analog Export ★ 2
Version: 1.0.1
Author: Jonathan Reichelt Gjertsen
Description: Exports analog measurements to “CSV”, that is, one row of data per sample. Please see README.md for caveats!
Extensions:
- Analog Export: Type: AnalogMeasurement
- Metrics:
- exp_hint: Export hint (exp_hint)
- exp_status: Export status (exp_status)
- Metrics:
Voltage Start and End ★ 0
Version: 1.0.0
Description: Provides the start and end voltages.
Extensions:
- Voltage Start and End: Type: AnalogMeasurement
- Metrics:
- v_start: Start voltage (Vstart)
- v_end: End voltage (Vend)
- Metrics:
Voltage Statistics ★ 1
Version: 1.0.0
Description: Provides mean, standard deviation, median, 5% quantile and 95% quantile.
Extensions:
- Voltage Statistics: Type: AnalogMeasurement
- Metrics:
- v_avg: Voltage (Vavg)
- v_std: Standard deviation (Vstd)
- v_med: Median deviation (Vmed)
- v_q05: 5% quantile (Q5%)
- v_q95: 95% quantile (Q95%)
- Metrics:
Analog Fundamental Frequency ★ 1
Version: 0.0.3
Author: Mark “Cool Guy” Garrison
Description: Measures fundamental frequency using autocorrelation.
Extensions:
- Analog Frequency Analysis: Type: AnalogMeasurement
- Metrics:
- fundamental: fundamental (f0)
- Metrics:
Rise/Fall Time ★ 1
Version: 1.0.0
Author: Fabiano Kovalski
Description: Measures average rise and fall time from 30% to 70%
Extensions:
- Rise/Fall Time: Type: AnalogMeasurement
- Metrics:
- v_30p: Voltage 30% (V30%)
- v_70p: Voltage 70% (V70%)
- t_rise: Average Rise Time (Trise)
- t_fall: Average Fall Time (Tfall)
- Metrics:
HummingBird: I2C SPEC testing ★ 3
Version: 1.0.0
Author: Peggy Lin
Description: Automated Electrical Test for I2C Signal
Extensions:
- HummingBird: Type: AnalogMeasurement
- Metrics:
- spec: spec check result (Pass/Fail) (FAILs)
- v_high_scl_worst: SCL voltage at the HIGH level (VH,scl)
- v_low_scl_worst: SCL voltage at the LOW level (VL,scl)
- v_high_sda_worst: SDA voltage at the HIGH level (VH,sda)
- v_low_sda_worst: SDA voltage at the LOW level (VL,sda)
- v_nh_scl_worst: SCL noise margin at the HIGH level (Vnh,scl)
- v_nl_scl_worst: SCL noise margin at the LOW level (Vnl,scl)
- v_nh_sda_worst: SDA noise margin at the HIGH level (Vnh,sda)
- v_nl_sda_worst: SDA noise margin at the LOW level (Vnl,sda)
- t_rise_scl_worst: SCL max Rise Time (Tr,scl)
- t_fall_scl_worst: SCL max Fall Time (Tf,scl)
- t_rise_sda_worst: SDA max Rise Time (Tr,sda)
- t_fall_sda_worst: SDA max Fall Time (Tf,sda)
- t_low_worst: Minimum low period Time (Tlow)
- t_high_worst: Minimum high period Time (Thigh)
- f_clk_worst: max clk frequency (fCLK)
- t_SU_STA_worst: RESTART setup time (TSU,Sr)
- t_HD_STA_S_worst: START hold time (THD,S)
- t_HD_STA_Sr_worst: RESTART hold time (THD,Sr)
- t_SU_DAT_rising_host_worst: rising data setup time (TSU,dat, wr,r)
- t_SU_DAT_falling_host_worst: falling data setup time (TSU,dat, wr,f)
- t_HD_DAT_rising_host_worst: rising data hold time (THD,dat, wr,r)
- t_HD_DAT_falling_host_worst: falling data hold time (THD,dat, wr,f)
- t_SU_DAT_rising_dev_worst: rising data setup time (TSU,dat, rd,r)
- t_SU_DAT_falling_dev_worst: falling data setup time (TSU,dat, rd,f)
- t_HD_DAT_rising_dev_worst: rising data hold time (THD,dat, rd,r)
- t_HD_DAT_falling_dev_worst: falling data hold time (THD,dat, rd,f)
- t_SU_STO_worst: STOP setup time (TSU,STO)
- t_BUF_worst: bus free time between STOP and START (TBUF)
- Metrics:
Area Under Curve ★ 0
Version: 1.0.0
Author: Joao Vieira
Description: An extension for Saleae Logic Analyser that determines the area under curve of an analog measurement.
Extensions:
- Area Under Curve: Type: AnalogMeasurement
- Metrics:
- area: Area (Vsec)
- Metrics:
Current Consumption ★ 1
Version: 1.0.0
Author: Jenish Rudani
Description: An extension for Saleae Logic Analyser that determines the area under curve of an analog voltage measurement against 18 Ohm resistor to determine average current consumption
Extensions:
- Average Current Consumption: Type: AnalogMeasurement
- Metrics:
- Iavg: Current (Iavg(Vavg/18))
- Vavg: Voltage (Vavg)
- Imax: Current (Imax(Vmax/18))
- Vmax: Voltage (Vmax)
- Metrics:
Saleae Measurements V2 ★ 2
Version: 0.0.3
Author: Saleae
Description: Saleae built-in V2 Measurements
Extensions:
- Voltage Measurements: Type: AnalogMeasurement
- Pulse Measurements: Type: AnalogMeasurement
- Time Measurements: Type: AnalogMeasurement
